MalakiArtook :
l0v3rboi :
Either one is a good choice. CPU temps on both using any one of those coolers are within 1-2 degrees celsius of each other. I would prefer the U12S because of its smaller dimensions and quieter operation.
thats a good point. the slightly better cooling isnt really worth it for the size. it is so heave id be afraid to put it on my MOBO. really anything noctura is top notch though and you cant go wrong.
So is there any difference between
Noctua NH-U14S
and
Noctua NH-U12S
Or are they both roughly the same thing?
