Question CPU cooler for an Intel i7-2600 CPU ?
Ayatollah
78
Hi, i'm looking for a budget cooler for my Intel i7-2600 because the stock cooler can't really cool it tbh.
What would you recommend?
In some situations, you may not have much option for changing the cooler or really much else unless this is a "standard" type build. With the likes of Dell and HP they tend to do things that stand as an obstacle to changing the components.
Reactions: stonecarver
It's mix and match of 2 pcs, a zoostorm one from 2011, and an Advent DT1404
It's in the advent dt1404 case, and the cooler can be switched around because that motherboard was using the stock intel cooler, but then i switched it for the cooler of the other pc which was this spire sleeve cooler, idk the model but it's getting like 2000 rpm while booting and on the home screen. I replaced the cooler because the cpu it cooled before the i7 had the same tdp so i thought it would cool it just as well
Well I'm going to assume it can't fit a 15 cm cooler then 90 cm fan at rear is a give away
2 models come to mind
This coolers barely 12 cm tall
https://uk.pcpartpicker.com/product/9v3NnQ/thermalright-assassin-x-90-se-43-cfm-cpu-cooler-ax90-se
I would get another fan and fan clips for the 90
You may be able to squeeze the following in 2
https://www.google.com/url?sa=t&sou...gQFnoECBQQAQ&usg=AOvVaw1qYWs8hnqT89P66-GRHKn5
