CPU cooler for Intel Core i7 980X Extreme Edition 3.33 GHz(Urgent)
cocliosttro
51
Please advise what is good cooling for Intel Core i7 980X Extreme Edition 3.33 GHz 12MB Socket LGA1366 i might clock CPU later i want to be sure that i am not ending up with poor cooling.
The D14 mentioned above is a beast of a cooler, both in size and performance.
The Megahalems is also a good choice, then there's the VenomousX as well.
Follow Wolframs advice and read some reviews at Frostytech to help you decide which would be best for you.
if you're planning on overclocking, i'd suggest the Promilatech Megahalems also
or watercooling, if you don't want alot of trouble just get a set from swiftech for $299
