Some of you might remember me posting a thread about running Prime95 and my CPU reaching 63C. I had been using the stock cooler, but this was too hot for me. The stock cooler was also very loud, which I didn't like. I decided to order the Zalman 9700 NT CPU cooler from Newegg. Initially I was going to order AS5 along with the cooler, but decided not too because I had read the included Zalman Super Thermal Grease(STG-1) was just as good.
I decided to install the cooler today. When I took off the stock HSF, I noticed the cured pre-applied thermal compound was thicker than what people have ALWAYS recommended to me: the layer should be as thin as possible. Moving on, I took a lint free cloth, dabbed it with isopropyl alchohol, and cleaned off the CPU. Out of all the computers I've built, this is the first that I have installed an aftermarket cooler.
I opened the STG-1 and noticed it's a lot thinner than the AS5. More like a nail polish consistency. I put a circle of the grease in the center of the CPU. Diameter was about the diameter of a quarter(obviously not as thick though). I took a piece of grocery bag, put it over my finger, and spread grease outward trying to make it as thin as possible.
I took the cooler and put the AM3 latch through it as shown in the picture. I took out the video card so I could put it on easier. I put it on, pushed down the latch until it locked on. Plugged in the cooler. I hooked up the computer and booted into Windows. After all the startup items were done loading, I opened HWMonitor and watched the temp slowly decrease. I let the computer idle for about 5 minutes and the temp had reached a minimum of 35C(hovering up slightly every so often). Previously the temp had reached a minimum of 37C. I'm down 2C on idle. Not breathtaking, but still lower than stock.
I wanted to get a load temp, so I opened Prime95 and ran the blend test. Something that I did not expect happened. Previously, when I ran the test with the stock HSF, the temp would gradually increase and eventually would peak at ~61-63C. This did not happen with this cooler. The temp increased rapidly and I watched it climb, 62, 63, 64, and eventually reached 70C before I would NOT let it go any further so I stopped the test. I decided to check and make sure the HSF was on right, so I powered down. I noticed it wasn't EXACTLY(I emphasize this word) centered, I turned it ever so slightly so it appeared to be as centered as possible. Booted up again. Idle was the same, but again when running Prime95, the temp SHOT up. 62, 63, 64, 65, 66, 67. I didn't want to chance it, so I stopped the test.
I was thinking the consistency of this stuff is so thin, and maybe I didn't put enough on the CPU. So I powered down. Took the HSF off, cleaned it and the CPU off as I did before. This time I put a slight bit more, but still rather thin, because, again, as I've heard from the majority, it SHOULD be very very thin.
Booted into Windows again. Minimum idle temp again at 35C. When it came time to run Prime95, again, the temp rapidly increased. This time not as fast but still fast. I decided to let it run for a few minutes. It got to 66 rather quickly, but the increased slowed. 67 came more slowly, and 68 a lot slower. So I assume the extra bit helped very slightly being the temp wasn't increasing as fast, but this was still way too hot, so I stopped the test.
I began getting worried, so I decided to put the stock HSF back in and just put the new cooler in next weekend. I cleaned off the stock HSF and CPU. I applied some of the STG-1 to the CPU. This time just a bit more than what I previously used on the Zalman. FAST FORWARD. Min idle temp 36C. When running Prime95, the increase was a lot more gradual, but I still peaked at 65C. Still too hot. Also, the stock HSF is no longer revving up to 6700rpm under load with CnQ OFF(I'll have a question on this). I began thinking maybe this "grease" needs to be applied thicker than traditional compound. I reapplied it again, this time using a bit more.
So I tried a bit more and now and have the current results. Min idle down to 35C. When I ran Prime95, the temps increased a lot slower this time. But still, the fan didn't rev up to 6700rpm max like it had originally. After 15 minutes, I was peaking 62-63C. This duplicates what I had previously experienced with everything stock.
Outside of Prime95 testing, things seemed slightly cooler than stock. Idle was down 1-2C. I reset my temps and played COD4 for a bit. Previously when playing COD4, my CPU would max out at 61C. This time it maxed out at 58C. So now my questions:
1. Question about the stock cooler: Why is AMD including a HSF with the CPU that allows the CPU to reach its upper limits in the first place? I know stock is stock, but come on. Upper limits?
2. Does the "thinner is better" apply to both compound and grease, or just compound? In my situation, this didn't apply to grease.
3. Previously my stock fan would rev up to 6700rpm, but now it doesn't. I have CnQ off. Why would just switching to grease cause this to happen?
4. Is Prime95 considered a good OVERALL load test? I mean, my gaming load temp has dropped, but Prime95 is still reaching upper limit temps. Should this program only be reserved for truly maxing out the CPU, but not necessarily be considered a good OVERALL load test? Am I giving Prime95 too much credit?
5. Should I use AS5 thermal compound the next time I install the Zalman?
