Question CPU Cooler recommendations, plus PWM cooling and SSD heatsink questions ?
MasterYoda327
226
6
10,585
I plan to build a new gaming PC soon. The primary use will be for 1440p gaming (possibly 4K) with secondary uses being for basic drone 4K video editing and YouTube content creation. No overclocking is planned. Please note, I plan to build a separate content creation PC for the mentioned drone and YouTube tasks, but want my gaming PC to be able to handle those tasks in case the content PC is out for repairs, upgrades, or replacement.
Anyway, I am looking for a CPU air cooler to fit onto a Gigabyte X870E AORUS ELITE WIFI7 ATX AM5 Motherboard with G.Skill Flare X5 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory, and a Radeon RX 9070 XT GPU (undecided on brand and model at this time). I am looking for a CPU air cooler that has a balance between good cooling and good silence. I also want it to have sufficient clearance from the RAM and GPU and, if applicable, still have good clearance if the CPU cooler allows for additional fans to be added. What CPU air cooler would best meet my needs?
I also have two side questions:
First, I plan to connect a Noctua NA-FH1 Fan Controller between the motherboard and my PWM-capable case fans. Would I be better off connecting the recommended CPU cooler either directly to the motherboard or Noctua Fan controller?
Second, I want to provide cooling to my NVME SSD. I have selected the Crucial T700 W/Heatsink 2 TB M.2-2280 PCIe 5.0 X4 NVME Solid State Drive. Does the mentioned Gigabyte motherboard come with a heatsink that the Crucial can fit in and receive additional cooling? If yes, does this mean I can save some money and get the mentioned Crucial SSD without a heatsink?
Thanks.
Thermalright Peerless Assassin 120's are common suggestion as they're cheap and they are beefy coolers. What case are you going to be working with?
Noise is a subjective topic such as design, as there are people who can hear the ticking of the fan's motor while others won't even notice it.
Either one works.
Yes, the entire board has heatsinks for all of the M.2 slots on the board.. Though in hindsight, you should avoid removing the heatsink off of an SSD that comes with a heatsink as the aforementioned task can void your warranty.
It may be better to connect the cpu fans directly to the motherboard since this allows you to set the Temperature Interval (how quickly the cpu fans speed up when the cpu temp increases) to 1, the fastest level. Then you can set the case fans Temperature Interval to a slower level. (For example on Asus motherboards the fastest level for cpu fans is 2.1 seconds and for case fans its 12 seconds.) The Gigabyte manual does not seem to indicate how fast each of the fan connectors speed up so you may want to test this on your own.
Reactions: MasterYoda327
Noctua makes some of the best coolers, and they are quiet.
Quiet comes from large fans moving slowly; that means 140mm and not 120mm or less.
Without knowing your intended cpu it is hard to say.
Here is the noctua cpu sizing form:
https://ncc.noctua.at/cpus
Your case allows 185mm high, that will fit any cooler around.
Also, your ram is low profile, 33mm high which should not impact any cooler.
https://www.gskill.com/product/165/396/1662622664/F5-6000J3636F16GX2-FX5
Some motherboards locate the first X16 slot too close to the cpu socket, and that may impact some coolers.
Looks like you are ok for any cooler:
https://ncc.noctua.at/motherboards/model/Gigabyte-X870E-AORUS-Elite-WIFI7-6090
It looks like a m.2 heat sink is included.
With 3 front 140mm intakes, there will be plenty of fresh air moving over the motherboard to dissipate m.2 heat.
Re your first side question about where to connect the fans of the CPU COOLER:
Connect these ONLY to the mobo CPU_FAN header.
Why? Your mobo has two very similar fan control systems. Each actually is a TEMPERATURE control system that aims for a measured temperature at a particular sensor and manipulates its fans' speeds to achieve a temperature target. Neither actually cares about what the fan speed is. And BOTH have an extra important function to consider - monitoring the speed signal from its fans to detect fan FAILURE.
The CPU_FAN header uses for guidance ONLY the temp sensor inside the CPU chip, so it is the one you can rely on to cool the CPU properly. (The mobo SYS_FAN headers use a different sensor on the mobo, and are suited for case vent fans.) The CPU_FAN header also has extra protection in case of detected fan failure. IF it decides the CPU cooling fan has failed, it may shut down your system very quickly without even waiting for the temp sensor inside the CPU chip to report high temps. This is to protect the expensive CPU chip from permanent damage due to rapid temp increase with NO cooling. Many mobos also will not even allow you to start up if the CPU_FAN header does not receive a valid fan speed signal when it first starts.
The CPU_OPT header basically is a complete copy of the CPU_FAN header and is very useful if you have more than one fan for CPU cooling to plug in. On some mobos you cannot configure this header separately, but the BIOS manual for your board indicates that may be possible.
For your case ventilation fans, use the mobo SYS_FAN headers. The Noctua NA-FH1 Fan Controller you plan to use actually is not a fan Controller. It is a fan HUB. It uses the speed control PWM signal from one mobo SYS_FAN header to control the speeds of all fans connected to it, and provides power to those fans directly from the PSU via a SATA power output connector from the PSU, thus drawing no power for fans from the host SYS_FAN header.
