Hi all
I have been asked to check/replace the thermal paste on a PC however I have run into a bit of a problem removing the CPU cooler. There is a thin metal retention clip that runs underneath the fan which is clipped in either side - but for the life of me I cannot seem to get it unclipped. 🤦♀️
I have attached a couple of photos - any advice would be very much appreciated. Happy to provide more info and photos if required. Also, please ignore the dust - it will be getting a thorough clean before I return it.
Thanks in advance!
Thanks in advance!
