Hi
I would like to get this CPU cooler (http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-tx3/) due to it being better than the stock cooler and its ease of installation but I have three questions.
When I'm install the CPU cooling, so I'm looking down at the motherboard with the back of the case to my left and the front panel to my right, do I put the fan on the left or right side and should it suck air out or blow air in??
I have seen the odd review of the plastic pins breaking. Is this just the persons own fault while installing it or is it something that could happen to me?
Then my last question is in the future can I change the fan if I wanted to? Can the metal clips on the fan be taken off and put on a different fan so I could put the new one on if need be?
Thanks community
Thanks community
