CPU Cooler suggestion for Cooler Master HAF X
sooduhnim
Hello,
I am a first-time builder, and I am looking for advice on a CPU Cooler to fit inside the Cooler Master HAF X.
I purchased a Noctua NH-D14, but I am having trouble with it fitting inside the case. Specifically, the backplate mount is very thick and does not line up with the side opening on the internal case part of the Cooler Master HAF X and my motherboard ASUS P8Z77. Because the backplate is so thick, the motherboard does not sit completely flush with all of the stand-off screws. Specifically, while the bottom screws are flush, the top right screws of the motherboard are not .
I am hoping for some advice on my options. First, can I buy slightly longer stand-off screws to create more distance between the interior case wall and the motherboard so that the backplate does not get in the way? I believe I am currently using about 6mm stand-off screws (measuring exposed portion only) and 8mm should work. I'd prefer this option as I like my current CPU Cooler, but only if it will not damage the board.
Alternatively, I could purchase a new CPU cooler. I would prefer the cooler to be as quiet as possible because my wife is often nearby while I use the computer, and I'd prefer for her not to feel like she's in an airplane hanger. The major limitations on the cooler would be the case that I currently have and the motherboard/RAM that I have currently installed. For the motherboard/case, I would be wary of any backplate that is too thick because it would cause the same problem. For the RAM in particular, I plan to use all 4 slots, and I don't want a cooler that will obstruct the third/fourth slot. I have listed the major parts below.
Thanks!
Approximate Purchase Date: e.g.: this week
Budget Range: Less than $80
System Usage from Most to Least Important: gaming
Are you buying a monitor: No
Parts to Upgrade: Heat
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com, amazon.com
Parts Preferences: by brand or type: none
Overclocking: Yes
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Additional Comments: Generally, I would like a quiet PC.
And Most Importantly, Why Are You Upgrading: My current CPU cooler isn't fitting
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
ASUS P8Z77-V LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.amazon.com/gp/product/B007G51UWY/ref=oh_details_o00_s00_i00
Noctua 6 Dual Heatpipe with 140mm/120mm Dual SSO Bearing Fans CPU Cooler NH-D14
http://www.amazon.com/gp/product/B002VKVZ1A/ref=oh_details_o02_s00_i01
Intel Core i5-3570K Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I53570K
http://www.amazon.com/gp/product/B007SZ0E1K/ref=oh_details_o02_s00_i02
XFX FX797ATDBC Double D HD 7970 Black Edition 3GB DDR5
http://www.amazon.com/gp/product/B006W3ZU4U/ref=oh_details_o02_s00_i04
CORSAIR HX Series HX750 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
