CPU cooling upgrade
Jun 14, 2012
72
I am currently rocking the original heat sink that came with my FX-6300 which I purchased about 2 months ago so I really need a upgrade. I am a bit tight on money right now and I will be for a while. I have been looking at the cm hyper 212 and the cm V6. I am only looking to do only little overclocking. I usually do however run most my games on high setting. I also have a NZXT Tempest 410 case. Which one should I get?
212+ or Evo are great cheap coolers, and when you want to upgrade to a better cooler all you really need are better quality fans, which are super easy to replace on either cooler.
