G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
When I first built my Athlon 64 (NForce3-based) system, the system ran
pretty hot. Idle at 45 degrees, and it would often go as high as 60
or 65 degrees. The CPU fan usually started at 3000 rpms when I start
up the computer, then worked its way up to 4500 rpms after a few
minutes (and stayed there).
I fiddled around with the system, installing better drivers,
rearranging case fans, fooling around with the Bios, and so forth.
Eventually I got the idle temp down to 37 degrees, and with a heavy
workload it can only go as high as 55 degrees.
But now the CPU fan is plateaus at 3000 rpm! It stays there even when
the CPU temp gets into the 50s. However, when the system is
sufficiently cool, the fan will slow down to the 2000 rpm range. So
the fan can slow down, but can't get faster than 3000 rpm. Any idea
why?
why?
