Hi!
My cpu-fan was really loud so I decided to get a new cpu cooler, but the cpu temperature goes up to 100 C instantly after startup even though I think I installed the new cooler correctly. I cleaned the old thermal paste off and the cooler came with pre-applied paste. When I switched back to the old cooler (with new paste) the problem consists, so I doubt it's a problem with the cooler itself. The cpu fan is working as expected, turning at full speed and being loud. I don't think it's a faulty sensor because there are multiple sensors in the cpu, all showing over 96 C in hwmonitor.
One more thing: I can't get either one of the coolers off the normal way. When I pull up the rotating plastic bits, the cooler becomes loose and can wiggle around. Once it even "bounced" up the moment I pulled up the first plastic-bit, but in order to come off completely, I have to push them out from the backside of the motherboard. Maybe something is broken and the cooler doesn't mount properly? I would appreciate any help, thanks!
Motherboard: ASUS GL12CP
CPU: Intel Core i7-8700
Cooler: Be quiet pure rock slim 2 (It was the best one I could find for the price which still fits in my case)
