Hello all. First time posting here and looking for some help with an issue some others seem to have faced also, albeit with a slight difference. Recently installed a cooler master hyper 212 evo heat sink for my intel 15 4670k processor onto a asus gyrphon z87 mobo. As some others have experienced, when booting up I am given an error message stating "cpu fan error" and am required to push f1 to proceed. I am able to bypass this by restarting and everything runs fine from then on. I have read this issue can be dealt with by changing the minimum fan speed in the bios.
HOWEVER, and this is the difference between my problem and the others, on boot, after pushing f1 the bios screen freezes after about ten seconds and I am forced to restart. The cpu temp in the bios reads as 80+ degrees, but when viewed from the intel tuning utility from within windows it only reads as 30 degrees. Is my cpu really this hot on boot up? This seems impossible. Should I just ignore the bios reading and take the steps recommended to others or is there more to my problem than this?
Thank you
Thank you
