CPU Fan Heatsink not covering whole of CPU
NaliD
My CPU fan heatsink (Cooler Master Hyper 212 Plus) is not covering less than 1mm of the CPU and I was wondering if that is a problem.
Should be perfectly fine if your CPU socket type is listed as compatible. The visible part on the CPU top is just a lid/heat spreader, not actually representing the actual size of the interior heat generating parts.
