[SOLVED] Cpu fan on sys fan header
Jun 25, 2020
11
So my cpu 4 pin header on the motherboard is not working and i have connected the cpu fan header to the system fan header, now it is working.
My question is that, is there will be any change in the fan speed?
If so what should i do?
I don't want to buy a new motherboard.
Will the fan run at the max speed which was provided bn the 4 pin header?
You will have no issues running the fan of the SYS Fan header and as it is a 4 pin PWM fan the fan will be auto controlled via BIOS so no issues at all...Just set the profile in the BIOS to quiet mode and it should auto ramp up under load..
So that means it will run perfectly on the 3 pin sys header?
And i have set it to quiet mode, but what are these modes?
Is it not suitable to put it on normal mode?
In which mode the fan will run at full speed?
