CPU Fan (Red light after blue)
Did that, tried to see in the bios again, nothing shows.
The screenshot on speedfan is here:
Okay, now one more test and this is vital. Google "BurnInTest" and download the software from passmark.com website. After installing the software, run "Maximum CPU Temp" from Quick Tests menu found at the menu bar.
If you are not able find the software, here's the link:
http://www.passmark.com/products/bit.htm
The test should run for 15 minutes and it will automatically stop, displaying "Passed". If it throws error while testing, stop the process and must afford a new fan.
Most welcome, OP. You really don't need to worry about your computer's temperature if BURNINTEST shows 'Passed'. BurnIntest software is really powerful and efficient in reading the temperature under heavy load for each component in the cabinet. And that's why, it's a paid version.
