CPU fan rpm
I read it using HWMonitor. For the model I am not sure. I opened the cpu case cause I thought the model of the fan is in there but it seems nah? How would I know the model
There are 2 fans inside a cpu case right? One is the one inside the gpu I think? And the other one is the one that u will first see once u open the case. Are both fans the same?
Seems like its impossible to know the fan with that plain looking fan ? ahhaa. I'm really nervous , Whats the disadvantage of having a fan run at 8k rpm which sounds impossible so what is causing it ?The fan sounds normal tho
