Hi all!
I've bought my AMD Athlon 64 X2 6000+ (3.0 Ghz)+Stock FAN one year ago, and im using the ASUS M2R32-MVP mboard.
I've noticed that on winter (on normal pc usage), that my CPU Fan reaches 3000-3500 rpm with 40-45ºC on my CPU.
I'm from portugal, and summer has just started with an 32ºC external temperature, witch makes my cpu fan shoot up to 6500-7000 RPMS and 45-49ºC, this on normal pc usage (just some websites and msn on, nothing more).
So is this cpu fan speed normal?? Because it really makes alot of noise!!
I have 3 120mm fans on the case, + 1 80mm fan. Ive already changed the thermal paste 2 times (arctic 5 silver...), and the results are the same...
Anyone have an ideia? Could it be my stock cpu fan now working properly? Maybe the mobo (some temp sensor not funcioning well maybe...)?
Thanks in advance , and wish anyone can help me, because i start to get worried...
