Hi, I have setup a new build, left the case panel open, after booting to BIOS I noticed that the cpu fan is starting and stopping repeatedly.
At Smart fan 5 I verified the values, it was switching between 0rpm and 50rpm speeds. After setting to max throttle and restart there was no difference.
I am using the AMD provided stock Wraith stealth cpu cooler. I verified the connections too, tried with one stick of ram, switched it, no difference.
I don't have a GPU because I am planning on using the iGPU of the processor. Haven't touched anything else on the settings except in Smart fan 5.
Today i am going to try with a new psu, current psu is a 420w one, but as far as I calculated I am not using more than 200. The components are new. All components are compatible as far as I know.
The BIOS version is F1, motherboard rev 1.1. I can provide additional information if needed.
Temperatures: the cpu is idling at around 40C, chipset goes up to around 60C, I am not putting it under load as it might damage components.
The question is what could be the problem with the cpu fan speed in this case ?
My setup:
Mobo: GA-AB350M-DS3H
CPU: Ryzen 3 2200g
2xRAM: CMK8GX4M2B3200C16R
PSU: 420W
My setup:
CPU: Ryzen 3 2200g
PSU: 420W
