Hello everyone,
I've recently built a PC (http://www.tomshardware.co.uk/forum/359843-13-cheap-gaming-linux-build), which essentially consists of the following:
Motherboard: ASRock H77 Pro4/MVP
CPU: Intel Core i5 3450 (using the stock heatsink & fan)
RAM: Corsair 2x4GB DDR3-1600 XMS3
GPU: EVGA GeForce GTX 560 Ti
SSD: Samsung SSD 830 Series 128GB
PSU: be quiet! Pure Power L7 430W
Now, the system is running perfectly fine so far and I haven't had any issues yet, but there's one thing that somewhat annoys me. When booting the system, the CPU fan seems to start about 3 seconds after everything else has already started (case fans etc.). Essentially, after pressing the power button, I can see the fan "twitching" twice (it starts moving a little two times), then it spins very loudly (presumably at full speed?), but slows down immediately to the speed it normally spins at. As I said, it takes a few seconds until it actually starts spinning at full speed, as opposed to the case fans, which start spinning immediately. All fans are connected to the motherboard.
The fact that the fan starts at full speed and then slows down doesn't really bother me, my old AMD CPU did something similar (unless there's a problem with that). However, the delay is strange to me. If I look at the CPU temperature in the BIOS immediately after starting, this doesn't seem to overheat the CPU; in fact, it runs rather nice and cool (about 35°C), but because I've put together the thing myself, I want to be sure that I didn't mess anything up. Basically, what I'm asking is whether I need to worry or if this is normal.
