CPU Fan too loud
Mitko2624
23
Hello guys,i have an CM T2 Blizzard cpu fan,and the power cable has 3 pins,in my motherboard there are 2 place where i can put it,in the 4 pins where it type CPU FAN,and the other place with 3 pins , where is types SYS Fan,when i put it in CPU Fan its like the cpu fan is louder than the SYS FAN slot.What can cause this?
The CPU fan plug is meant to control a fan for your CPU cooler. You should be using that one for your cooler.
The Sys fan plug is meant to control a fan that blows air to cool your motherboard.
Your CPU fan will go faster if the motherboard detects that your CPU is getting hotter. So when you plug it into the CPU fan plug, it will be going faster than the Sys fan plug, thus being louder.
As i see my CPU FAN is at 2300 rpm,which means 100% , atm my proccesor is like 35-40 Celzius,how can i control the cpu fan , i tried with bios, doesnt work , tried with speedfan it doesnt work..
