CPU fan too loud
metamp
25
Ok I finally reinstalled my P4 3Ghz CPU and this time removed the retail paste from the heat sink and CPU and used the artic silver 5
the temperatures dropped by 5 deg. C but still when I play a game the CPU temp is 55 - 60 deg C which is ok but the fan is screaming at 5800 rpm
Man this thing is too loud
I'm considering water cooling
Any experience or suggestions
Nights_L
1,452
Buy sth that you can adjust the fan speed..or add a resistor for your CPU fan..but of course, you have to make sure it won't get overheated
pitsi
650
You could buy a high-end heatsink, such as the SLK947-U or maybe even the SP-94 if you can afford it, along with a fan like SmartFan II, whose speed can be manually adjusted. This way, you could get the same results as the stock HSF but by operating the fan at lower speeds.
For example I have an Athlon XP at 1.65v vcore voltage and I am using a SLK800 with SmartFan II. I have the fan's speed set to 2500rpm which is almost silent and I have never exceeded 47C load.
<b>blah:</b> <font color=red>Don't show your stupidity, whole world knows that Intel is a much better CPU for stable work.</font color=red>
