CPU fan wont scew into motherboard
Andrew_283
4
Hey, so i'm building my first pc here and i am trying to screw the cpu fan into the motherboard, i've lined it up with the holes but when i try screw it down nothing happens and it wont stay!
I'll include pictures
pls dont judge if i am being stupid and forgot something
http://imgur.com/gallery/ZEbRE
First thing is - that fan and heatsink are dirty. Clean them up with compressed air before installing.
Second - you need to make sure cooler is designed for your type of socket (1150)
Third - if it is boxed cooler, your motherboard manual has detailed info on all steps required to install it. If it is aftermarket cooler, check the manufacturer's website for manual.
