My CPU died while running a heavy load script.
I built this PC about 10 years ago, MSI 760gm e-51 (fx) MB, 8350 AMD CPU. Only problems I ever had was overheating (shutdowns) while playing games, which I eventually fixed by adding a liquid cooler to the CPU. It ran fine for the past couple years, my only concerns were optimizing graphics to get a better fps in Skyrim SE. One avenue of that process is LODGEN, which optimizes distant viewing among other things. The last process I tried was generating occlusion files, where the script goes through the game files and generates new/different occlusion files to make the game 'better'. I don't claim to understand the ins and outs and the whys and hows. So let me get to the point.
While running the script, my pc shutdown, which hadn't happened since I installed the liquid cooling. So, I rebooted and turned on my hardware monitor and re-ran the script. This is where you'll realize I am an idiot, and this will be proven again in the near future :-0. So, I ran the script again, carefully monitoring the CPU core temp, as the process went from 50--60% done the CPU temp was rising above 60c, then to 70c, then to 80c and it was 95% done, so I foolishly thought I could eek out the process, but the pc shutdown just before it finished. I waited a minute and tried to reboot, but all I got was a soft 'pop' sound and couldn't restart into POST. So I figured I fried it and I ordered a replacement 8350 CPU. I installed it and the pc booted up just fine and everything was back to normal. And then I got really stupid, and decided I'd try running that script again, but this time I'll watch the CPU temp and cancel the process if the temp got over 70c. But, this time it got about 50% done, the CPU temp never got over 45c and the pc shutdown again. So, I pressed the start button and I hear that soft 'pop' sound again and the pc won't even POST again. Same exact scenario, but it apparently had nothing to do with heat.
What could possibly cause this? Is there a way to reset or fix the CPU? Was there some voltage setting captured in CMOS that fried it on reboot? How could running a script do this? Any insight or help is appreciated.
