Hello everyone,
I’m experiencing an issue with my PC's cooling system. The liquid inside the pipes is no longer flowing, and upon startup, I receive a warning that the "CPU temperature is too hot." Sometimes the system boots, and Windows opens, but the CPU temperature remains high, around 70-75°C.
I couldn't find a drainage pipe to replace the liquid, which hasn't been changed in years.
I took the PC to a repair shop, and the technician informed me that the pump is damaged. He quoted me $300 for the repair.
I suggested replacing the liquid cooling system entirely with a standard air cooler, but the technician advised that it would be even more expensive since my system uses a dual cooler for both the CPU and GPU. Additionally, I no longer have the original cooler that came with the GPU, so a separate GPU cooler would also need to be installed.
Would like to hear your input on the matter what should i do?
Thank you.
Thank you.
