AMD FX-8320 Vishera 8-Core 3.5 GHz (4.0 GHz Turbo) Socket AM3+ 125W FD8320FRHKBOX
XFX Radeon R9 390X DirectX 12 R9-390X-8256 8GB 512-Bit GDDR5 PCI Express 3.0
Team Vulcan 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model TLYD38G2133HC11ADC01
Corsair CX Series 750 Watt 80 Plus Bronze Certified Modular Power Supply (CP-9020061-NA)
WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
Cooler Master MasterLiquid Lite 120 All-in-one CPU Liquid Cooler with Dual Chamber Pump, INTEL/AMD with AM4 Support
4 - 80mm side fans
Quick rundown, my computer kept going to black screen in middle of medium-high resource games; I ran HWmonitor to see if something was overheating; CPU was sometimes running 70c idling; I got cooler master 120 lite and installed, CPU now idling around 20c; so that was fixed but ever since i put cooler in, I am getting now artifacts/flickering to freezing and crashing my system; thought my GPU was overheating, hottest it got was 70c under load, idles at 30c, but during crash times, i did feel hotter air than what HWmonitor was saying at 70c, but maybe not, just for note;
things i tried in between; replacing SATA, PCI-E cords from PSU, resitting RAM, cleaning the hell out of everything, applying new thermal paste to GPU
Heres the mess of what happens
https://imgur.com/a/9S3DQ
NOTE - sometimes i can play for 5-10 minutes, sometimes its mere seconds, but it does mean that the card isnt complete shot
How can I tell if GPU is going bad, or if im trying to get much wattage than i have, or if CPU is just damaged even though i have temp stablized?
4 - 80mm side fans
