Hello my dear fellow Tom's
I hope everyone is well and good.
Recently I had to replace most parts of my Asus G53JW Laptop but I have some problems well one problem to be exact and that is random sudden shut downs. (now I think I have pinpointed the source but do not know what exactly to do)
Laptop in question is: ASUS G53JW
i7 740QM
GTX 460M 3G
8G DDR3
[/b]NOTE: No Dust in whole system - Good Thermal Paste have been applied - Fan working fine - Maybe bad heatsink?
I replaced the Motherboard, VGA, LED Panel, Keyboard, added a new SSD (250G Adata + 1 T Samsung/Seagate 2.5 HDD)
After I get everything together I installed Win 7 which worked fine for a little while and I even run some benchmarks which gave some odd results but then suddenly without no reason shut downs began, random shut downs even where there is 0% load.
I changed windows to Windows 10 64bit enterprise edition and it worked fine for 3 days but after that random shut downs started to appear.[strike] I have no idea what is the cause of cuz shut down happens[/strike] even when system is not under load or gaming or anything it is 100% random. Last night I tried to run Far Cry Primal on it but every single time when it reaches the first loading screen after starting a new game boom sudden shut down! This is the first time I can do something to result in a direct sudden shut down.(Other games such as Battlefield 3 Ultra settings, Far Cry 4 and any other games work just fine) But games that use CPU cause CPU heat to go over 100'c and boom shut down. Intel says max = 100'C. 101 = dead
Another odd thing is that the VGA temperature do not drop below 80'C(most of the times) which sometimes is 60'C (normal themp)
Also check these benchmarks on the photos see if everything is okay VGA wise.
What should I do? Where the fault lies?
Please help me on this one.
P.S Sometimes after a sudden shut down I get a bluescreen after boot (INACCESSIBLE BOOT DRIVE or Partition)
P.P.S My original VGA was 460GTX 1.5G but this one I am using is GTX 460M 3G which is odd!
http://gpuz.techpowerup.com/16/05/28/8rz.png
http://prntscr.com/b9foi7
http://prnt.sc/b9fg7o
http://prntscr.com/b9fq6r
http://prntscr.com/b9fqa0
Well so far I can tell the HEAT is the devil behind all this misfortune but what causes the CPU and GPU to go under such a load that makes them so damn hot which results in sudden shut down? here are two screenshots of TjMax and system has no load at all.
and TJMAX
One more odd thing, when I use Asus Pwer4Gear Hybird program and switch from High performance to quiet office everything drops to the level they should be but at High performance everything spikes to max and system shuts down.(With no load)
Please help you old friend out of this stinky situation before I fry my CPU or GPU
Thank you so very much in advance for reading and responding.
With Great Respect
Neo
i7 740QM
GTX 460M 3G
8G DDR3
and TJMAX
With Great Respect
Neo
