CPU I7-7700K Running 100*C
gunnygucho
6
Hey Guys, my computer after doing a windows update and NZXT CAM software update has been running at 100*C on all cores. Both the CAM software and the MOBO bios state the CPU temps are at 100*C.
I ran an update yesterday before getting off my computer and today when I start it up multiple times my fans on my Kraken X62 spin up completely. I don't feel any heat on the RAD or the pump. I built this computer a month ago and every once in a while on boot up it would spike to 75-80 for a second or two then come right back down and everything would be fine.
PC Parts:
Intel I7-7700k
NZXT Kraken X62 AIO v.2
MSI Z270 Gaming Pro Carbon
EVGA 1080TI FTW3 Hybrid
G.Skill Trident Z RGB 16GB
M.2 NVMe 512 960 EVO
2TB WD Black
I have already checked the temperatures in two places as stated above and not sure it's a false reading considering one is from the MOBO and one from the AIO cooler. I checked to see if the AIO pump was installed correctly and am 100% sure it is. I also tried tightening the pump and on two of the screws I could get another 1/4 turn. Didn't fix the issue though. What else could be wrong?
<a href="http://s1345.photobucket.com/user/Gunnygucho/media/Mobile%20Uploads/20171004_195459_zpsrjbsqkcb.jpg.html" target="_blank"><img src="http://i1345.photobucket.com/albums/p675/Gunnygucho/Mobile%20Uploads/20171004_195459_zpsrjbsqkcb.jpg" border="0" alt=" photo 20171004_195459_zpsrjbsqkcb.jpg"/></a>
<a href="http://s1345.photobucket.com/user/Gunnygucho/media/Mobile%20Uploads/20171004_195709_zps3j0d5gql.jpg.html" target="_blank"><img src="http://i1345.photobucket.com/albums/p675/Gunnygucho/Mobile%20Uploads/20171004_195709_zps3j0d5gql.jpg" border="0" alt=" photo 20171004_195709_zps3j0d5gql.jpg"/></a>
Would a bad pump cause the Clock speed to be as erratic as it is? I'm jumping for 800-4400.
High temperature will cause erratic behavior, get a good cooler first.
I am going to buy a Noctua NH-U14s to try out while I RMA my NZXT. Thanks for your help and will update Friday if the issue is fixed.
Thanks for your help guys as I stated above I'm going to buy a Noctua NH-U14s as a temporary solution with my X62 gets RMA'd. I will update Friday to let you know if the issue is solved. Thanks again.
