Question CPU I9 9000K Help With Settings And 5ghz Speed?
XxDarkMario20xX
322
16
4,865
26
Hi there i just got the new cpu last month and upgraded to i9 9000k but i want 5ghz but my temps full load is between 65-80 and know this is powerful cpu and dose heat up but just wanna make sure went into bios change my settings speed to 5ghz and the cpu voltage is set to auto just wanna make sure these pictures are ok Placed cpu at auto now so just wondering if want to change it to 5ghz what should the voltage settings should it be under bios
Also running two monitors on 165hz refesh rate and 2k settings also posted this thread just to make sure that my bios is not over doing the voltage on my cpu because heard it can heat it up fast
View: https://i.imgur.com/hOay17V.jpg
View: https://i.imgur.com/MsKt3eQ.jpg
Specs
Intel Core i9 @ 3.60GHz Kaby Lake 14nm Technology
Ram 16GB DDR4 3000mhz
Gigabyte Technology Co. Ltd. Z390 AORUS MASTER-CF (U3E1)
3071MB NVIDIA GeForce RTX 2080 Ti (MSI)
What’s the system used for and why are you overclocking. I get overclocking can be done just for fun but just thought it is worth pointing out that if gaming across 2 2k monitors that even with a 2080Ti I expect the gpu will usually be the limiting factor. Therefore overclocking the cpu may not bring any material performance gain and just extra heat.
jankerson
Judicious
BANNED
I have the same MB, here are the settings I use for my 9900K.
Set CPU speed to 50.
Set VCORE to 1.30V
Set LLC to Turbo
Disable Multicore Enhancement
Set CPU TDP to 255
Enable XMP Profile 1
And that's it, nothing more and it's rock solid for me, the VCORE settings might be different different on yours.
Runs at 5 GHz on all cores.
