S Soham_95 Commendable Aug 24, 2016 102 0 1,680 Jul 28, 2017 #1 If cpu is not seated properly(somewhat slight inclined,askew),would that create problem?
superninja12 Glorious May 18, 2015 11,378 56 49,140 Jul 28, 2017 #2 yes a major problem Upvote 0 Downvote
superninja12 Glorious May 18, 2015 11,378 56 49,140 Jul 28, 2017 #6 Soham_95 : but what sort? dead cpu dead motherboard. Upvote 0 Downvote
Ne0Wolf7 Reputable Jun 23, 2016 1,262 5 5,960 Jul 28, 2017 #7 The motherboard has pins on it where it touches the CPU in specific areas. If the CPU is not seated correctly, you could bend the pins and ruin the motherboard, and ruin the CPU while your at it Upvote 0 Downvote
S Soham_95 Commendable Aug 24, 2016 102 0 1,680 Jul 28, 2017 #8 my pc boots.would it die Upvote 0 Downvote
Ne0Wolf7 Reputable Jun 23, 2016 1,262 5 5,960 Jul 28, 2017 #9 It boots even when its in wrong, or did you fix it? You may have dodged a bullet. Upvote 0 Downvote
Ne0Wolf7 Reputable Jun 23, 2016 1,262 5 5,960 Jul 28, 2017 #11 If its working at working I guess. would have expected it all to be broken, but it seems not if its working. Upvote 0 Downvote
S Soham_95 Commendable Aug 24, 2016 102 0 1,680 Jul 28, 2017 #12 need to check?or fine..costly i7 Upvote 0 Downvote
Ne0Wolf7 Reputable Jun 23, 2016 1,262 5 5,960 Jul 28, 2017 #13 Using it is the check. You could run a stress test to see if it's unstable, but if its working thank the socket gods and enjoy your PC Upvote 0 Downvote
S Soham_95 Commendable Aug 24, 2016 102 0 1,680 Jul 28, 2017 #14 http://m.cpubenchmark.net/high_end_cpus.html my i7-4790 score 10,100turbo boost disabled audio is cracking sometimes http://www.tomshardware.com/answers/id-3480780/audio-chip-malfunctioning.html Upvote 0 Downvote
