Hello, i have a p8z68 mobo and an i5 2550k with an older H100 water cooler.
I dont know much about how the radiator works to cool the cpu, but two fans are running. I felt the tubes, water is 100% moving.
The motherboard gives me a CPU Fan error and i press f1 to get into bios. The bios detects my chassis fan not my cpu rad. Should i try the cpu_optional header?
The cpu fan header is plugged in for my h100. What can i do now? Cpu reaches 100 degrees in 2 mins.
Edit: wait a minute.. the cooler seems to be functioning, liquid flowing and fans spinning. Why would it overheat then.. all the 3 pin fan header does is tell the mobo the rpm and voltage, right? I dont care about the 3pin then, do i?
