Cpu is overheating, fans are spinning though.
ttg_Avenged
545
Hello, i have a p8z68 mobo and an i5 2550k with an older H100 water cooler.
I dont know much about how the radiator works to cool the cpu, but two fans are running. I felt the tubes, water is 100% moving.
The motherboard gives me a CPU Fan error and i press f1 to get into bios. The bios detects my chassis fan not my cpu rad. Should i try the cpu_optional header?
The cpu fan header is plugged in for my h100. What can i do now? Cpu reaches 100 degrees in 2 mins.
Edit: wait a minute.. the cooler seems to be functioning, liquid flowing and fans spinning. Why would it overheat then.. all the 3 pin fan header does is tell the mobo the rpm and voltage, right? I dont care about the 3pin then, do i?
Do you have any other cooler? Is so, check with that.
As someone said before, your tubes can also become jammed, as you said you hear the pump running and coolant running.
Reapply thermal paste ✓
Potentially blocked passageways in the tubes ✓ No solution I guess if this is the issue I will never know?
I guess I will make a new thread if you are out of ideas. Thanks for your help on this issue!
