I'm getting quite worried about my cpu temps on stress tests programs, especially prime 95. I have a pre built pc from Dino pc and the cpu is overclocked to 4.3 and a voltage of 1.224. The cooler is a Corsair H60 Water Cooler and it seemed to be working well. My temps on idle are 30's and during games 50's but stress tests kill it with 80's or even low 90's. I installed speed fan and noticed the speed of my cpu fan doesn't increase at all as temperature increases. Is this the problem or is the cooler just faulty ?
On a side note i uninstalled speed fan after messing with automatic fan setting (i turned it on) i became nervous that it might mess even more with my cpu temps and uninstalled it, I also made sure to delete all the files (even in my registry) is it completely gone and no longer having an affect as i don't want to damage my cpu.
Thanks for any help you can give.
