CPU led status and CPU fan on after shutdown
Migeru32
Commendable
Jan 14, 2017
24
I have a gigabyte aorus z370 ultimate gaming v2.0 and an Intel i7 8700k
I have stripped my build down to the motherboard, CPU, CPU cooler, Ram, and PSU.
I have also reset the motherboards CMOS and have done a couple reinstalling of windows 10 version 1703
But when I shut down the pc the CPU fan still left running along with the led status indicator for the CPU
Your problem is that the cpu light and the cpu fan stay on while the computer is off correct? The motherboard might be the issue then. The psu has a switch inside that is controlled through the 24 pin connector to the motherboard which should turn off the power to most things when the computer is shut off.
SeaSonic S12II Series S12II 620 Bronze (SS-620GB) 620W Intel ATX 12 V 80 PLUS BRONZE Certified Active PFC Power Supply this is my power supply and I have tested it on another set of motherboard and CPU, and it works fine
I too belive that the mobo is the problem and will try getting its warranty
