Question Cpu light is solid red on my motherboard
Jun 26, 2019
I was updating drivers and I had to turn off my pc for a audio driver and then my pc would not turn on. The cpu light on my MSI B450m Mortar is on. I am considered because I built this system in January of 2019. And I don’t really have a idea of what is happening. Also I don’t have a graphics card
Check the Installation Guide for the motherboard if you have it.
If not, I found the following link:
http://download.msi.com/archive/mnu_exe/mb/E7B89v1.4-GSE-LITE.pdf
(Note: Do verify that the linked motherboard manual is a correct match to your motherboard.)
Per Page 36: "CPU - indicates CPU is not detected or fail"
Troubleshooting suggestions are on Page 87.
Overall, check that all cable connections, card seatings, jumpers, etc. are all fully and firmly in place.
