A couple of days ago I turned on my pc and I encountered an error which said "usb device over current status detected". I, then, unplugged the front panel usb connectors from the mobo and it started but I couldn't receive video signal. At that point I changed the position of the ram sticks and it started normally. After a little while I noticed that the cpu temperature where higher than normal and the liqmax ii 240 fans were going faster. Yesterday playing the cpu reached 85/90°C and so I proceeded to shut the pc down. I've noticed that only one tube was super hot. I've also noticed that when I turn the liqmax ii 240 at full speed the cpu doesn't cool down at all (sometimes it seems to get hotter). Should I change the cpu cooler? Is it a cpu/mobo problem?
