CPU Overheat? 1700x & GTX 1080 Ti w Cryorig H7 Cooler - Premiere Pro / Encoder System Crash
ScrappeyDP
133
I built a system for Video editing but I am having issue with the Render causing my system to crash.
I have CUDA set on and think it has something to do with the CPU temps because as soon as I try to render my CPU temps will shoot up into the high 80 degrees C.
Is it possible my H7 Cryorig Cooler is seated incorrectly? Should my temps be that high? Could there be something else causing the crash?
The entire system will power off during the render before it can complete leaving the partial files behind.
I haven't had any issues while editing, but have issues consistently when rendering. I have tried with Media Encoder and Premiere Pro CC and can reproduce using both methods.
Any advice is greatly appreciated.
AMD Ryzen Master Screenshots during rendering https://goo.gl/photos/RUy58YBTLW2EHdBRA
Thanks!!
OS Name Microsoft Windows 10 Pro
Version 10.0.15063 Build 15063
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name --------------------------------
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor AMD Ryzen 7 1700X Eight-Core Processor, 3500 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 0807, 7/19/2017
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume4
Locale United States
Hardware Abstraction Layer Version = "10.0.15063.502"
User Name ------------------------------------
Time Zone -------------------------------------
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 25.4 GB
Total Virtual Memory 36.7 GB
Available Virtual Memory 29.3 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
How would I check voltages?
Do you think the AMD Ryzen Master is reporting actual temp or is it also 20 degrees off?
I actually let it cool, restarted into BIOS and changed my type of cooler back to the stock using rhe EZ Wizard setup, it seemed like it knocked me back from 3600Mhz 3.6Ghz down to 3500Mhz 3.5 Ghz with the same voltage it was previously using for 3.6
Temps still skyrocket when rendering then drop back to the 40s after, but with my case open and an external house fan pushing air into the case while it blows its own fans did keep me rendering thru the nights. Big spikes under load then it drops.
Is it possible my cooler was not installed correctly? I had to use retrofit bracket for the cooler because of AMD Ryzen socket so maybe that's causing issues? I used the best arctic silver I could purchase...
I don't really know what that means... but should my temps be in the high 80s on AMD Ryzen Master program?
How can I monitor the voltage while it is rendering?
