Recently, I got a new motherboard, the ASUS crosshair v formula-z, and now my cpu is overheating by quite a bit during gameplay. When I first moved my cpu (AMD FX 8320) to the new mobo I didn't reapply thermal paste because I didn't have any and the old thermal paste still looked good. But I started up csgo and immediately after going into a casual match my pc shut off without warning, which usually means overheating. After that I replaced the thermal paste with some ThermalTake compound I got at best buy, and my results were actually slightly better. By around 30 seconds before shutting off...
This never happened on my old motherboard, but I installed a cpu temp reader. My cpu after being left running for 10 minutes is acting really weird. When left idling for 10 mins without side panel on it stays around 35-40C, but with side panel its around 40c. That seems very normal to me. But when I put it under any load it spikes to 70, and I'm never paying close attention when it shuts down, so I don't know if it spikes above 80-90C (the limit on my mobo), but I would assume that it does.
Do I have a faulty motherboard? is it reading temps wrong or something?
PC Specs
CPU: AMD FX 8320
Cooler: Stock FX cooler
Motherboard: ASUS Crosshair V Formula-Z
Graphics Card: Msi GTX 1050 ti 4gb
Ram: 32 gigs of Hyper X Fury 1866mhz
Case: Fractal Design Meshify C
PC Specs
CPU: AMD FX 8320
