So I got a ek a240 loop in my pc when I first installed it I had trouble mounting the cpu waterblock so I used my old cpu waterblock for my aio and it worked but the temps were high so I decided to install the mounting hard wear it came with but two of the standoffs were too big and didn't fit through the motherboard but I filed the standoffs so it would fit but my cpu is even hotter 40C idle 91C to bluescreen during a chinebench run. Im using a i5 8600k at 5ghz at 1.33 volts. (There is dents in the radiator from shipping too if that means anything) I also took a ir temp probe to check the water in the tubes and the temp stayed at 95F idle and load.
