Cpu parked Help
krisschils1256
284
Hello anyone who has read this i have a quick probelm...With battlefield 4 and titanfall i have been getting lowfps and stutter 90% everyone says to unpark my cores i used the program that is "suppose" to unpark them but to no avail
so i watched something about unparking cores in regedit and i did what he said and found this http://imgur.com/hYXkIxw, is this why i dont have my cores unparked, is it suppose to be like that? any help is appreciated
Specs FX 6350 oc to 4.0ghz
GTX 660
8gb ddr3 ram
You might also try going to Power Options, then change the MIN and MAX of the CPU to 100%.
There is a lot of confusion about this problem.
For BF4, Windows 8 works better as well. Not most games, but for BF4 they modified some code. That may be specifically to prevent core parking in Windows 8 but I'm not sure.
You can try this as well: http://coderbag.com/Programming-C/CPU-core-parking-manager
Other:
Your problem MAY be a core parking issue, but it also could be caused by having settings too high, and/or normal issues with these games. I can't say in your case.
I would recommend trying the LOWEST quality settings to see how smooth things run with VSYNC OFF.
I did all you said and no dice....still cores 3,5, and 1 are still parked
If we go back a bit in the post i never rreally got a straight answer does 06cadf0e-64ed-448a-8927-ce7bf90eb35d
have any meaning with the possible parked cores?
