So I'm having a problem with my new PC specs are
Motherboard - MSI X570 WiFi edge
CPU - Ryzen 5 3600x
PSU - Thermaltake 850W gold
GPU - Radeon Rx580 8gb
When I go to power on PC everything is connected properly it doesn't turn on at all. I breadboard it and took components out to try powering it up. When I plug in the CPU 8pin nothing happens. Once I unplugged the 8pin my motherboard turns on . I plugged in all my satas and GPU without the CPU power plugged in and it turned on.. Once I plug the CPU 8 pin PSU turns off or doesn't turn on.. Is it to weak of a power supply.. or is something wrong with the CPU or Motherboard?
CPU - Ryzen 5 3600x
