*UPDATE 4/17/11*
Somehow the BIOS set the CPU speed to 4.2 Ghz. I set it back to the standard 3.3 Ghz with 3.7 Ghz target for turbo. I ran the test again with the following results:
CPU-Z
Core Speed at 100% CPU Load- 3.4 GHz
Core Voltage at 100% CPU Load- 1.20 V
HWMonitor
Max Core Voltage- 1.23 V
Max Temperature- 76 C
RealTemp
Max Temperature- 79 C
This definitely helped bring down the temperature significantly (over 10 degrees), but it still has me a bit worried that I am getting a reading of almost 80 C at 100% CPU load.
*UPDATE 4/17/11*
It seems that the flip flopping of temperature data was an issue with SpeedFan (possibly a bad install or download to begin with) because Real Temp gave me readings that made a lot more sense. I performed the Prime95's Blend Test with it and while I am still not enthused about the results, they are much better than before. I am now at 35-40*C with 0% CPU usage and I peaked at 90*C on one of the cores (the others were very close as well) at 100% CPU usage. This is still quite high and I plan to try reinstalling the cooler, trying a third temperature monitor to make sure Real Temp is accurate and it truly was SpeedFan, and I suppose I will get a new CPU cooler if all else fails. Any other suggestions are still appreciated.
I finally finished building my PC and decided to run the tests suggested on the Tom'sHardware Step-by-Step Guide to Building a PC since all I could check before was the BIOS reading which showed my CPU running around 50*C. I chose to use SpeedFan to monitor my temperatures for the suggested test.
I installed Speedfan and gave my system a restart so I could start the test nice and fresh. I started up SpeedFan and began running Prime95’s Blend Test. I took a look at the digital readings and the graphical display and saw my CPU and AUX temps were both showing with a distressing flame next to their temperature readings with the AUX reading around 60*C and the CPU read from 80*C to 90*C from before the Blend test was started. Then right at the time of the Blend test, the CPU immediately dropped and stayed between 35*C and 45*C while the AUX dropped to around a constant 55*C. I ended the test, and then instantly, my CPU temperature shot up to 90*C and my AUX back up over 60*C.
This seems completely counter-intuitive to me. When my PC is idle, running absolutely no application the temperature is a dangerous 80*C plus. When I am running a stress test it drops by half to 40*C. What in the world could be happening? Why are the idle temperature in the OS so much higher than when I boot into the BIOS?
I am running the stock CPU cooler with the stock pre-applied thermal paste. Should I replace the thermal paste? The entire cooler? Is this even an issue with the cooler if it can reach 40*C?
Build
i5-2500K (no OC) with stock cpu cooler and pre-applied thermal paste
ASUS p6p87 B3LE
8GB 1066mhz
Corsair FS60 SSD
Samsung Spinpoint F3 1TB HDD
Antec 300 with stock 140mm and 120mm rear and top fans
CPU-Z
HWMonitor
RealTemp
*UPDATE 4/17/11*
Build
ASUS p6p87 B3LE
8GB 1066mhz
Corsair FS60 SSD
