CPU running too hot
DarknessRising
33
I am having problems with my cpu running really hot its not overclocked its gets really really hot during gaming at 69°C i am using ASUS Suite 2 to look at the tempertures i am getting really worried and holding back gaming as much as possible this just started a couple of weeks ago i upgraded my fan from the AMD 8350 Stock Cooler to the Hyper 212 Evo and still having overheating issues any comment would be greatly appreciated
Computer Specs
CPU: AMD FX 8350 4.0 Ghz (Stock)
CPU Cooler: Cooler Master Hyper 212 Evo
Case: Fractal Design Define R4 White Artic White
Case Fan 1: Fractal Design R2 Silent Series (front)
Case Fan 2: Fractal Design R2 Silent Series (rear)
Motherboard: ASUS M5A99FX PRO R2.0
Graphics Card: R9 270x Dual-X Sapphire 2 GB GDDR5
Power Supply: EVGA SuperNova NEX750B 750w 80+ Bronze Certifed Power Supply
RAM: 8 GB DDR3 G-Skill RipJaws X Series
Hard Drive: 2 TB Seagate Barracuda 7200RMP
OS: Windows 7 64 Bit Ultimate
That temperature is totally normal, the max temp of your CPU is 125 degrees, so honestly if that's the maximum heat its outputting there's nothing too worry about.
I don't have an FX 8350,but 69°C doesn't seem that high of a temperature.
My rule is,if it's under 75°C it's all good.If you're not convinced,just download OCCT and run the CPU test.
That information is completely wrong i think you mean 125 degrees fahrenheit
i have tried to remove and reapply the paste already
Thank You :)
its slightly better than my stock cooler at 72 while gaming i do have turbo enabled in my BIOS
why should i underclock it when there are people running it at 4.0 Ghz with the stock cooler under 60 degrees could that mean the cpu is damaged?
I doubt its your CPU cooler.
The thing that is most likely to go wrong would be a malfunctioning socket, but of course there is no way to test this theory without buying a whole new board (Not practical at all!)
And yes @zoddiakku those temps should honestly be a bit lower but they're not going to do any long term damage either.
Is your case dusty? @darknessrising also how many fans do you have on your case
my case isn't dusty at all i clean it every single week with compressed air
You need a real cpu cooler like a DH14 with a 8320 or 8350. The Hyper 212 Evo of which I have three is ok with say a 4300 or a 6300 or a Deneb or even a Thuban. Not so much with an eight core.
really thinking of spending for the Swiftech H220
Well,if it's still under warranty just take it back to the store and ask for a replacement.It could be a defective socket(or the CPU itself).You could try a new cooling solution(or installing it on a different mobo to see if it's the cpu or the socket),but the easiest way would be to take it back to the store.
