CPU running too hot
DarknessRising
33
I am having problems with my cpu running really hot its not overclocked its gets really really hot during gaming at 69°C i am using ASUS Suite 2 to look at the tempertures i am getting really worried and holding back gaming as much as possible this just started a couple of weeks ago i upgraded my fan from the AMD 8350 Stock Cooler to the Hyper 212 Evo and still having overheating issues any comment would be greatly appreciated
Computer Specs
CPU: AMD FX 8350 4.0 Ghz (Stock)
CPU Cooler: Cooler Master Hyper 212 Evo
Case: Fractal Design Define R4 White Artic White
Case Fan 1: Fractal Design R2 Silent Series (front)
Case Fan 2: Fractal Design R2 Silent Series (rear)
Motherboard: ASUS M5A99FX PRO R2.0
Graphics Card: R9 270x Dual-X Sapphire 2 GB GDDR5
Power Supply: EVGA SuperNova NEX750B 750w 80+ Bronze Certifed Power Supply
RAM: 8 GB DDR3 G-Skill RipJaws X Series
Hard Drive: 2 TB Seagate Barracuda 7200RMP
OS: Windows 7 64 Bit Ultimate
That temperature is totally normal, the max temp of your CPU is 125 degrees, so honestly if that's the maximum heat its outputting there's nothing too worry about.
Not really, the TDP of the 8350 is 125W and the CPU cooler supports 130W TDP, meaning that is should easily be able to cool the cpu.
Also did you put thermal paste on top of the thermal paste already applied to the heat sink?
as a build up in thermal paste results in insufficient cooling.
i am 100% sure that i cleaned my cpu with isopropyl
