[SOLVED] CPU running with maximum temperature
Arun Rajan
7
Hello,
I recently configured a PC with following components. Its a new computer barely 1.5 months old.
i9 10900K
8GB 2080Super
64GB ram
Cabinet - Antec NX 600
msi core liquid 360r
While doing normal tasks the temperature is 40 degrees, But when I start rendering (Blender Cycles) its boosting to 85-100 at 100% load. Is it because of less air intake? Can anyone suggest a solution?
I can't see where the air is even supposed to pass through at the front... so what are the fans bringing in, if not recirculating the already heated air inside the chassis?
Without spending money:
A)Did you mount the fans to pull air through the radiator?
For reference:
iu
B)Go into bios and disable Intel Turbo Boost. Yes, you'll lose performance, but having it run that hot wasn't any better.
Spending money:
Straight up, get rid of that chassis, and get one that...
For reference:
iu
Spending money:
Straight up, get rid of that chassis, and get one that actually allows air to reasonably pass through it.
