[SOLVED] CPU Spiking; System fault?
Jun 21, 2020
Howdy, folks,
I have assembled a new system.
However, I do get CPU temp spikes from time to time.
in idle mode (no programs are running in the background; freshly set up windows with the most necessary programs), it jumps to ~70°C from time to time.
Default is at ~40°C (HWMonitor in Bios it's around 30°C).
system specification:
https://pcpartpicker.com/list/qB37jp
Bios:
View: https://imgur.com/a/aaCdBHH
Instead of the default thermal paste from the AIO, i used https://www.thermal-grizzly.com/produkte/2-kryonaut
The amount should be okai, not to much, not to less etc. not the first build i created; but stuck at this right now... :/
Greetings Sir_JaWa
EDIT: I just let CPU-Z CPU-Stress-test run for 10 min. Temp maxed ~68°C
Did you assemble the parts list on your own, or did someone else do it for you, because it is a MESS - can't tell if it's budget, mid, or high end build, because the selection is a mix of all.
Just a rant - ignore it.
-A 150USD AIO on a 3300X
-The 3300X in an X570
-Just 3000mhz memory
-Samsung SSD in a build that has no real identity
-RX 5500XT with a 650w Platinum rated psu
-The Define 7
1)Did you spread the thermal paste over the cpu IHS? The 'little in the middle, and the mounting pressure does the rest', does not work with the Thermal Grizzly - that's why the applicator is built into the tube.
2)Where is the radiator mounted in the chassis?
3)Check if you have the fans pushing air through the radiator or pulling air...
-The Define 7
3)Check if you have the fans pushing air through the radiator or pulling air through it instead.
Hey Phaaze88,
thank you for your fast response.
I got the parts quiet cheap (unused + new), so yeah. 😀
Kinda shuffled but it's fine sofar :)
1. The thermal paste was spread evently via the "Grizzly Bundle Spreader"-thingy.
2./3. The Radiator is mounted on top and the fans (3x120) are pushing through the rad.
Intake are 3x140+2x120 on around 600-800 rpm, should be plenty ^^..
Outtake the rad + 1x120.
