Hello All,
I've had problems with my less than 2 year old Acer Spin 3 for a year now, and have posted about it previously: https://forums.tomshardware.com/thr...-with-windows-explorer-and-streaming.3579514/
It got suddenly very sluggish after being lightning fast, and now it is to the point where it's nearly always too slow to do much of anything. I can't even use Zoom for work, so I need to fix this before I return to my job later this month or get a new machine. If I could just get some more months out of this, that would be very, very helpful.
The CPU speed is stuck at .4 Ghz, regardless of whether I'm doing anything. I've done tons of malware scans, have no bloatware left, and the 256gb SSD is nowhere near full. The person who responded last time suggested updating BIOS, which I haven't done yet as I'm worried it might cause problems? I'm happy to try it if people recommend it, I've just talked to two repair specialists who don't think BIOS is the issue. I started the laptop in safe mode just now, and while it was still pretty slow with basic tasks (Windows explorer, etc), the CPU was at 2.21 ghz as it should be.
With the fan on almost all the time and the laptop itself getting pretty hot if I try to do much, I downloaded CoreTemp to check the CPU temperature, which hovers at around 48 Celsius (not a huge deal as far as I can tell?). I'm tempted to use ThrottleStop, but also nervous I could make it worse. I could try opening the back up and cleaning the fan after watching YouTube tutorials, but just like with BIOS I'm more a noob than an expert and don't want to mess the thing up too bad.
Performance is the same whether on battery or plugged in. I've heard this could be a power supply issue (battery/performance settings are set to the max so that's not a problem), so I'm willing to buy a new charger, but not sure if that's the case if I'm having this issues while plugged in as well. My cat did chew on the cord a couple of times, and I'd be surprised if he is the culprit but hey, I'm stumped.
Any help is much appreciated!
Thanks,
T
Thanks,
T
