CPU super hot under load. Idle temp fine.
timberhoy
13
Setup:
i7 4790k (no overclock)
Corsair H60
Gigabyte Z97X-UD5H
Nvidia GeForce 770
Corsair RM650 power supply
RAM: Crucial Ballistix Tactical Tracer 16GB Kit (8GBx2)
Corsair Carbide 500R (two front intake fans(120mm), one rear exhaust fan(120mm), one side intake fan (200mm), two top exhaust fans (120mm with one pulling air through the H60 radiator).
My setup has been stable and fine since I built it initially a little over a year ago. Last week I was playing CS:GO and my computer hard shutdown (ie straight black screen) and auto rebooted. I quickly removed my headphones once it black screened and realized that my fans were the loudest I had ever heard them. My PC finished booting back up and I was able to get back in game, but my fans were still running super loud. Finished the match I was playing, shutdown the computer, and went to bed. Installed Core Temp the next morning to see what was going on with my temps. In the past I've idled around in the lower 30s, and lived in the mid 50's during 2-3hr CS:GO sessions. Suddenly now while playing CS:GO I'm hitting 70's within 20 minutes of starting a match.
That lead me to believe that perhaps the pump was going in my H60, or maybe the thermal paste was going bad. I opened up my case, took a look at my H60 to check that it was mounted solidly (it was). I went ahead and removed it, cleaned off the OEM paste, applied Arctic Silver 5 (pea method), reinstalled the cooler. Booted everything back up and the temps were the same as they had been previous to the repaste/reseat. Went ahead and requested a RMA from Corsair for the H60 thinking that it was for sure my problem. Went to Fry's today and picked up a Thermaltake Frio Silent 14. Installed it, and my temps are still getting incredibly high under load. (But still idling at 33.) With the Thermaltake cooler my PC got through 6 mins of Prime95 before the MoBo auto killed it.
To me that seems to rule out the H60 as being the culprit. So now the question is, what else could be my problem? I haven't installed any new programs or changed any settings between when my H60 was doing perfectly fine keeping my CPU cool and now. I've tried swapping coolers to confirm a H60 problem, but the issue is persisting. What have I missed?
28.7 uses very high AVX usage, among others, something that is very rare in actual programs, so tends to overheat any Haswell or newer cpu. 26.6 was the last decent, stable version that somewhat accurately represented maximums of any normal usage. So yeah, it's gonna drive that 4790k nuts running 28.7. As for h60 failure, it could either have been the paste, pump or fan, or low liquid levels. It should still be under warranty from corsair. Might be worth it to RMA, Corsair has been decent about clc failures
Yeah, requested a RMA from Corsair for the H60 and am sending it back. I'm 90% sure it was failing because even after I took it off, and reseated it with new thermal paste playing CS:GO would spike my CPU temps and crash the PC. Glad to know that the current (air) cooler and the rest of my system are solid, and that it's just the test I was running that was causing the failures after installing a new CPU cooler.
Thanks everyone for the advice!
