[SOLVED] Cpu temp normal or not??
auzk2410
18
i have i5 3470 3.2Ghz.But i think i'm having abnormal CPUs temperatures
i recorded Temp through HWmonitor and here are my results
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.9.0
Monitoring
Mainboard Model 2ADA (0x000000F8 - 0x00002748)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8772
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8772
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 72 01 00 00 00 FF 00 00 00 00 48 03 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 30 0A 20 00 00 00 00 00 00 00 00 00 00 00 00
70 09 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A30
Hardware Monitors
Hardware monitor ITE IT8772
Voltage 0 2.23 Volts [0xBA] (CPU VCORE)
Voltage 1 2.23 Volts [0xBA] (VIN1)
Voltage 2 1.99 Volts [0xA6] (+3.3V)
Voltage 3 2.82 Volts [0x8C] (+5V)
Voltage 4 8.88 Volts [0xB9] (+12V)
Voltage 5 -8.93 Volts [0xBA] (-12V)
Voltage 6 -8.88 Volts [0xB9] (-5V)
Voltage 7 2.74 Volts [0x88] (+5V VCCH)
Temperature 1 47 degC (116 degF) [0x2F] (TMPIN1)
Temperature 2 54 degC (129 degF) [0x36] (TMPIN2)
Fan 1 1767 RPM [0x17E] (FANIN1)
Fan 2 510 RPM [0x52B] (FANIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 15 FF 06 00 00 00 00 00 80 64 0F 00 FF 7F 28
10 1D AF 48 77 C0 00 82 82 FF 01 05 45 80 21 21 21
20 B9 B9 A6 8C BA BA B9 88 88 BA 2E 35 B9 CF F0 F0
30 5D 10 7D 40 22 80 00 B0 63 34 07 27 40 68 08 41
40 45 18 28 49 00 C3 5F 40 AD 6A D4 00 FF FF FF FF
50 FF C3 7F 7F 7F 40 00 00 90 69 E0 12 60 00 00 00
60 7F 7F 7F 80 00 00 0F FF 81 22 60 40 0C 05 0F FF
70 81 22 60 55 09 05 0F FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 02 30 01 02 01 5E 20 32
90 58 70 C5 00 58 70 E5 00 40 00 00 00 00 51 00 77
A0 CC EB EB EB EB EB EB FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor D3D
Hardware monitor AMD ADL
Voltage 0 0.80 Volts [0x320] (GPU)
Power 0 33.02 W (GPU)
Temperature 0 49 degC (120 degF) [0x31] (GPU)
Fan 0 0 RPM [0x0] (GPU #0)
Clock Speed 0 300.87 MHz [0x12C] (Graphics)
Clock Speed 1 300.00 MHz [0x12C] (Memory)
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 2)
-- Thread 1 2
-- Core 2 (ID 4)
-- Thread 2 4
-- Core 3 (ID 6)
-- Thread 3 6
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core i5 3470
Codename Ivy Bridge
Specification Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping N0
Technology 22 nm
TDP Limit 77.0 Watts
Tjmax 105.0 °C
Core Speed 1596.2 MHz
Multiplier x Bus Speed 16.0 x 99.8 MHz
Base frequency (cores) 99.8 MHz
Base frequency (ext.) 99.8 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Microcode Revision 0x1F
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
FID/VID Control yes
IBRS supported, disabled
IBPB supported
STIBP supported, disabled
RDCL_NO no
IBRS_ALL not supported
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 36x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins +4
Ratio 1 core 36x
Ratio 2 cores 36x
Ratio 3 cores 35x
Ratio 4 cores 34x
TDP Level 77.0 W @ 32x
Temperature 0 54 degC (129 degF) (Package)
Temperature 1 54 degC (129 degF) (Core #0)
Temperature 2 52 degC (125 degF) (Core #1)
Temperature 3 53 degC (127 degF) (Core #2)
Temperature 4 49 degC (120 degF) (Core #3)
Voltage 0 1.09 Volts (VID #0)
Voltage 1 1.08 Volts (VID #1)
Voltage 2 1.11 Volts (VID #2)
Voltage 3 1.08 Volts (VID #3)
Power 00 20.02 W (Package)
Power 01 13.71 W (IA Cores)
Power 02 n.a. (GT)
Power 03 6.31 W (Uncore)
Clock Speed 0 1596.19 MHz (Core #0)
Clock Speed 1 2593.81 MHz (Core #1)
Clock Speed 2 3591.43 MHz (Core #2)
Clock Speed 3 3391.91 MHz (Core #3)
Core 0 max ratio 36.0 (effective 36.0)
Core 1 max ratio 36.0 (effective 36.0)
Core 2 max ratio 36.0 (effective 36.0)
Core 3 max ratio 36.0 (effective 36.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306A9 0x00100800 0x7FBAE3FF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B0FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000281 0x00000000 0x0C000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x20202020 0x65746E49 0x2952286C
0x80000003 0x726F4320 0x4D542865 0x35692029 0x3734332D
0x80000004 0x50432030 0x20402055 0x30322E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00D00
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x00000048 0x00000000 0x00000000
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00081010 0xE0012000
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x22232424
MSR 0x00000194 0x00000000 0x00192000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001FC 0x00000000 0x0014005F
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000601 0x18141494 0x80000380
MSR 0x00000602 0x18141494 0x80000170
MSR 0x00000610 0x80008302 0x00148268
MSR 0x00000611 0x00000000 0x481DD74A
MSR 0x00000639 0x00000000 0x32659713
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000614 0x000D0000 0x01E00268
MSR 0x00000648 0x00000000 0x00000020
MSR 0x00000649 0x01E00000 0x00000000
MSR 0x0000064A 0x01E00000 0x00000000
MSR 0x0000064B 0x00000000 0x80000000
MSR 0x0000019C 0x00000000 0x88300000
MSR 0x000001A2 0x00000000 0x00691400
MSR 0x000001B1 0x00000000 0x88300000
MSR 0x00000198 0x00001F62 0x00001D00
MSR 0x00000199 0x00000000 0x00001D00
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000306A9 0x02100800 0x7FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00C00
MSR 0x00000611 0x00000000 0x481E4345
MSR 0x00000639 0x00000000 0x3265E3FC
MSR 0x0000019C 0x00000000 0x88310000
MSR 0x000001B1 0x00000000 0x88310000
MSR 0x00000198 0x000021F2 0x00002300
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x000306A9 0x04100800 0x7FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x481EC13B
MSR 0x00000639 0x00000000 0x326643B4
MSR 0x0000019C 0x00000000 0x88320000
MSR 0x000001B1 0x00000000 0x88320000
MSR 0x00000198 0x00002363 0x00002300
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x000306A9 0x06100800 0x7FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x481F4E39
MSR 0x00000639 0x00000000 0x3266B0B1
MSR 0x0000019C 0x00000000 0x88340000
MSR 0x000001B1 0x00000000 0x88330000
MSR 0x00000198 0x0000233A 0x00002200
Storage
Drive 0
Name WDC WD10EZEX-22BN5A0
Revision 01.01A01
Serial WD-WCC3F4906180
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2140001
Name Radeon RX 580 Series
Board Manufacturer 0x1DA2 (0xE366)
Codename Polaris
Technology 14 nm
Memory size 4 GB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1DA2)
Model ID 0x67DF (0xE366)
Revision ID 0xE7
Performance Level 0
Performance Level 1
Monitor 0
Model W2442 (LG Electronics (GoldStar))
ID GSM56CC
Serial
Manufacturing Date Week 5, Year 2011
Size 24.0 inches
Max Resolution 1920 x 1080 @ 59 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-61 Hz
Max Pixel Clock 150 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
As u can see my core temperatures are between 51-55 at Idle condition and they go above 70 c during gaming like apex legends etc...
Please guide me is it normal or i need to apply thermal paste or something...One thing more i don't have any cooler right now.THANX
Ye our atmosphere is too hot...The temperature in our city is normally 35-40C and i'm not using air air conditioner in my room...BTW guide me if i i need any cooler or not?
Then those idle temperatures are not bad. As long as you are usually under 80C and not over 85C you are okay -- so those stress tests indicate that you are running 5 degrees or so too high for regular use. Either use better CPU cooling or find a way to col the room -- perhaps a good fan.
You are fine with core temps up to 80C and never over 85C with that CPU when under gaming stress.
So those temperatures are fine, I assume that is not the idle temperature though, as it would be a little high for those unless in a hot room (high ambient temperature). Idle temps should be 35-40C ish.
Reactions: RodroX
I played with a Core i5 3570 (a bit faster than yours) at over 73°C (usually temps never went over 77°C and this was on very cpu demanding games) for years and the cpu still working fine!
(This was with stock cooler, nver used an aftermarket cooler with it).
The things I can think about it to try and make it a bit better:
  1. Clean the dust and dirt from inside your case, specially all the heatsinks and coolers (this has to be done with extreme carefull, the PC turn OFF and unplugged from the wall).
  2. After cleaning every fan and specially the CPU cooler, only if you know how to do it, clean the old one form the Cooler and the CPU and reapply new thermal paste (something like Arctic Cooling MX-4 or DeepCool Z9).
the thing i was using i5 3570 a month ago but it got fried due to spilling of water by my maid...
then i couldn't find 3570 anywhere and had to choose 3470...
Could u please state the difference b/w stock cooler and aftermarket cooler...(I'm totally a noob in this field)
And one more you're telling me to clean CPU cooler although i don't have one.Are u talking about any built-in cooler or am i missing something?
Power 02 n.a. (GT)
That says everything relevant. From clock speeds, you really aren't pushing the cpu to its limits, whatever you are doing isn't using much core power by necessity, so it's not at idle, but neither is it under extreme loads, or all clock speeds would be pegged to 3.6GHz±.
Power 00 : package power, you are only using 20w out of the 70ish watts that cpu is capable of. Meaning if you do start pushing high power usage through that cpu, it's going to far exceed the @ 54°C it's currently at. With your current cooler, I'd not be surprised at temps closer to 90's.
The best way for sure is to run Prime95 small fft. That's an 100% cpu load, the worst possible temp your cpu will ever see from any game. If the cpu can stay somewhere in the mid 80's, you are fine. If the cpu goes beyond 90's then you need a better cpu cooler.
These are the results after running Prime95 smal fft. for about 10 minutes..
Temperature 0 87 degC (188 degF) (Package)
Temperature 1 83 degC (181 degF) (Core #0)
Temperature 2 87 degC (188 degF) (Core #1)
Temperature 3 85 degC (185 degF) (Core #2)
Temperature 4 84 degC (183 degF) (Core #3)
Voltage 1 1.09 Volts (VID #1)
Voltage 2 1.09 Volts (VID #2)
Voltage 3 1.09 Volts (VID #3)
Power 00 56.57 W (Package)
Power 01 50.16 W (IA Cores)
Power 02 n.a. (GT)
Power 03 6.41 W (Uncore)
Clock Speed 0 3391.91 MHz (Core #0)
Clock Speed 1 3391.91 MHz (Core #1)
Clock Speed 2 3391.91 MHz (Core #2)
Core 0 max ratio 36.0 (effective 34.0)
Core 1 max ratio 36.0 (effective 34.0)
Core 2 max ratio 36.0 (effective 34.0)
Core 3 max ratio 36.0 (effective 34.0)
You said something about using Cpu full power how can i do that?
