CPU temp readings too low?
Imrizzle
6
Hey guys
I checked my cpu temps on coretemp and speedfan, and they seem to low to be accurate readings, was wondering what input I can get from anyone else on the situation, is there a way to re-calibrate the cpu temp sensor?
GPU = 23C
Core 0-4 = 9-11C
Specs
CPU i7 4770k (stock)
MB Asus Sabertooth Z87
GPU EVGA GTX 780 SC ACX (stock)
Thanks!
FunkyFeatures
859
Tried other programs than those? I usually use evga precision x and msi afterburner for gpu, and i dont really monitor cpu at all.
If that is your idle temp, that is extremely good i would say. I would say i am just fine when im under 40 for idle.
If that is your load temp, i would say something is wrong. That isnt normal. No matter how good cooling you have got.
Imrizzle
6
These temps are at idle and aircooled. I believe it is impossible to cool below ambient room temp (25C)., which raises my concern over this. I'll look into trying other programs when I get home in the evening, if anyone has any sugestions on what programs to use to monitor cpu temps I'd appreciate it!
Latest posts
