This is my current computer specifications:
- Motherboard: Asus Maximus X Hero 1151socket
- Graphics Card: GeForce GTX 1070 8GB Fabric OC
- CPU: Intel Core i7-8700K 3.7GHz ( @4.8GHz OC )
- CPU cooler: Corsair Hydro H115i PRO RGB
- Memory: Corsair Vengeance RGB DDR4 3600MHz ( @3733MHz OC ) 16 G
- Main hard drive : Samsung 970 PRO 512GB PCIe M.2 SSD
- Secondary hard drive : Corsair Performance Pro 240GB SSD
- PSU: Corsair HX750, 750W PSU Platinum
- OS: Windows 10 Pro 64bit
At this overclock my 8700k needs arround 1.320V to reach stability in p95 and occt and Cinebench.
I can also reach a clock of 4.7GHz with 1.295V
The question is: In cinebench i get a score of: Arround 1530-1545 on 4.8GHz clock
and on my 4.7GHz clock i reach arround 1497.
Is this to much of a difference or is it bad? the score difference that is.
And i was wondering at my 4.8GHz overclock i reach 75-81degrees celcius in stresstesting for 4-10hours.
But i usually never hit those degrees while gaming, Let's say i launch CS:GO through steam, and load a server then the processor cores hit arround 68-72degrees but fall back down to 50-64 degrees under gaming straight a way, it's just while launching programs or games it spikes and then drops under the gaming itself.
I was wondering if this is safe for a 24/7 use. Even tho i usually just use my PC for 6-12hours a day.
I've tested bot overclocks for more then 8hours+. and both run pretty stable with an AVX of 0, VCIOO 1.10, and VCSAA at 1.15.
Aswell my ram has a CL of 18.19.39 timings, i use the same timings and voltage on my 3733Mhz bump, and i've not gotten any errors of memtest or the windows memory diagnostic for many attempts atleast.
Also found out if i wanna push for 5GHz overlcock i will need atleast more then 1.35V for my CHIP, and i will not go further then 4.8, concidering my chip is not delidded!
